Well after fitting the newly welded sump. I've managed to do 200 miles before the clutch gave out.
Well least I believe it to be the clutch.
No drive in any gears. No noise etc. Noticed the slave on the 166 is above the gearbox so that's easy to check.
Can you change the 166 clutch in situ as the engine bay is quite large?
I imagine the clutch is specific to the 166 given it has a dual mass flywheel.
Anyone replaced a clutch on a 166 that's able to give advice.
So far this 166 is the most unreliable car I've ever owned.
