1 - 9 of 9 Posts
V
I thought i'd start a thread on this topic as I can't seem to find an old one.
I am restoring a series 1 Ti as you know.
The car still has its original 1200cc Engine & box in it
I also have a 1500 engine from a sprint & an 8v 1700cc unit from a 33 and numerous gearboxes.
I have for some time been thinking about what to do, which engine to fit. whatever happens I will keep the original engine & box as its original to the car from new & the numbers match old paperwork & MOT's etc.
I have also been offered a 16v 1700cc unit this week, i'm unsure if I can to go down that route as I was led to believe that it wasn't possible with inboard brakes. But having looked at the 1200 motor today which is still in the car I notice that the rear of the heads are well forward of the discs... So is it just an access problem or is it a physical impossibility to fit a 16v motor to an early car with inboard brakes? Also the front crossmember does this need changing, looks like it does. All info and advice welcome
car
i know you have to change the front crossmember for a 16v one as they dip down at either end also not sure about the issues with the inboard brakes but my brother has a 16v in his sud and just changed all the running gear to 33 stuff .
maybe ask that ahm company he would be able to tell you .
V
Thanks pat :) I wana keep the inboards so don't wana go to 33 running gear, just as its an early car and try to keep it as original as possible
rsfruitbat is running inboard brakes and a 16v motor in his 33.
He has all sud suspension with just the 16v crossmember. I think the only issue is that the standard 16v manifold is not compatible with the inboard brakes, so you'll need a custom made one which will clear them.
Another job for shrew maybe? :rolleyes:
Changing the spark plugs might be a bit of a pig though..
V
mmm..... sounds like it might be possible.....
K
there isn't too much to change if you want to run a sud box (inboards) on a 16V, did look at that when researching mine.
x-member as has been said to clear the deeper heads, exhaust also needs changing as it runs where the discs go.
you will also need to machine a notch into the gearbox bellhousing to clear the crank position sensor so i was told by bls which looking at my 16V engine in the shed appears to be correct (not that i ever doubt what they tell me ;)) but other than that it's pretty easy.
can't remember if there was any issue with the clutch spigot shaft bush?
V
Sounds not too bad kev, so presumably it could be run on carbs from my 8v motor? (don't want to run any high tech injection / ecu stuff!! as I would want to keep the original wiring loom and keep the rest of the car as original as possible might upgrade the wheels from 5j to 5.5j wide ones though!! :cheese:
K
running on carbs is the easiest solution. kammatic has done that with his.
steady on the wide wheels though! :lol:
V
Everyone knows 175 firestones were the best tyre ever!! :lol:
1 - 9 of 9 Posts
