the 2.4 gets a GT2256V, that's possibly a smaller turbo then this one.Why would a turbo designed for a 224bhp 3.2L engine be suitable for a 1.9?
The torque is way higher, as will be the exhaust flow.
I don't know the angle of the exhaust manifold flange, I use templates to make sure modified parts fit.I already clocked turbine hausing, and put the vacuum actuator. easy job.
Next to do is to cut flange from turbine housing and welding it in right direction and angle. Harder.
JS JTD you do you know what is angle of exhaust manifold flange? 37 degrees?
except the fact just two are used under normal circumanstaces...You'll also need to change some of the seven vnt control tables to get the most of it safely.
