21 - 40 of 41 Posts
Discussion starter · #21 ·
Well ive had no lights show up or warnings ( touchwood )
i think only time u get problems is if u go below a certain height or u damage a sensor/cable
Me n mate fitted them with not much problems just odd size tools that seem to be needed to undo everything.
That's great, thanks :thumbs: i really like the alloys on mine & i really like the multispokes like you have so if i do lower it i may even change the alloys too. Just to give it a slightly difrent look :) so far though i've only seen a few that suit the MiTo so will have to see. Your MiTo sounds pretty good too :thumbs:
Discussion starter · #24 ·
Just had another dyno today since having sports cat n induction
it managed 191.8 bhp n 198.6 fblt (in normal again)
Had to take fuse out this time as it wouldnt disable anything, bloody car...
Seem to be losing some boost low down compared to last time but higher up range is ok, so may have a small boost leak as i was expeting better gains.
Discussion starter · #26 ·
No its a one from who made custom exhaust.
Checked over all pipes n cant find no loose or damaged hoses so could of been the Y piece they used to take the boost pressure
Discussion starter · #27 ·
As i said a few more pictures of the mito Lowered ( 30mm eibachs ) now clean
just in need of spacers now which im having custom made, just waiting on them
Discussion starter · #28 ·
Fitted front upper n lower strut braces today few pics for ya
( can a nice admin change title of thread to something suitable my mito project or something a like Please )
front upper
Front lower
also fitted a cglock aswell ( these things are brill)
front upper
Front lower
Nice! Noticed much difference? Where did you buy the strut braces? :)
Discussion starter · #30 ·
Feels much better on turn in and more planted through the bend
I couldnt find any on a cloverleaf so thought I would give it a try :D
they was off ebay, sellers username was strutbracer I think
Discussion starter · #31 ·
Ok thanks. I take it the engine cover doesn't fit underneath?
Discussion starter · #33 ·
It fits back over fine , it bolts up level to another bar
I just took a pic without as u cant see it when cover is back on
Discussion starter · #35 ·
Yes u have to drill
This should clear it up , I forgot uo upload it
Theres 2 self tappers each side then we have drilled an extra hole n put a bolt through
Something else to add onto my to do list :rolleyes:
:lol:
Looks really good though, if it makes a difrence to the handling then its even better :thumbs:
Great results, can we see the graph. Rollers can over read but even so 193hp is alot over the claimed 170hp.
Would like to see what mine still makes 5years on now!
when i had mine on a RRD, the guy had to unplug the ABS behind the wheel as there is no mention of the abs fuse in the manual so we didnt know which was the right one.
This seemed to stop the cars TC kicking in (Stupid thing having the TC on in Dynamic anyway, why Alfa did this i dont know).
Wonder though was this running fully in Dynamic by him doing this or was it in Normal even if switched to D?
As someone mentioned in a previous post that if the fuse is out the car only runs in N.
Yep will post a graph tonight.
Yeah we had to pull fuse no. 40 from under the bonnet on my mito and the G's.
This meant my car wasn't running at 270nm torque that it would if it was in D mode.
A GQV pretty much did it's claimed 235bhp, but a 170bhp diesel G recorded 188bhp completely stock! Then he added a tuning box and it recorded 217bhp!
Sent from AutoGuide.com Free App
21 - 40 of 41 Posts
