Mito MultiAir and turbo failure
1 reading
10K views 29 replies 16 participants last post by  Ian Lusso
#1 ·
On 22 August 2016, I purchased pre-owned 2011 Alfa Mito 1.4 Progression from a well-known BWW dealership in Bellville. At the time of the purchase the vehicle had 89556km on the odo and had a full Alfa Romeo Service Record. The previous owner took out an extended Warrantee/Service Plan that ends at 30/03/2017 or 90 000 kilometres, whichever occurs first.
On 23 November 2016 with 92000km on the odo the MultiAir Unit failed and was replaced at a cost of roughly R16000 by the well-know BWM dealership – kudos to them. The repair work was excellently carried out by Auto Azzurri in Cape Town. A month later the turbo charger failed and had to be replaced at a cost R11697,81 out of my own pocket. This was also excellently done at Auto Azzuri. The oil feed pipe to the turbo was also replaced at this time. This puts the total repair bill for a car with a full service history with only 92 000km on the odo at roughly R28 200.
I realize this is not a new car but I find it disturbing that these expensive failures occurred at such relatively low kilometres.
I have engaged with Alfa Romeo/FIAT South Africa on 25 January 2017 to see if there are any way they can assist. I have not heard anything from them, except for a request for information that I originally supplied them with.
Any idea's on who's door I can go knock for a response?
#3 ·
First 2 services (30 000km and 60 000km) was done at Chrysler/FIAT/Alfa Umhlanga and 90 000km was done at Chrysler/FIAT/Alfa Century City. Maybe I should get them to send me the job cards for these services. Surely if the wrong oiled was used they have some responsibility?
Ja, Giorgio told me to make sure correct oil must be used and changed every 10 000km. He did an oil/filter change as well with correct spec oil.
#7 ·
The MultiAir units are very sensitive to oil spec.
I had my Mito QV serviced at Cargo Motors and they used Castrol. A month later I started getting engine lights and warnings. I immediately went to Alfa Boksburg and got the correct Selenia Star 5w40 and did an oil and filter change myself. The car was happy after that.
Only two oils with correct spec for MultiAir is Selenia and Mobil 1.
Edit: You now get a Mobil 1 0w40 spec oil.
#9 ·
only ever had a small missfire on my MA due to low oil but nothing else. serviced every 10000 with new oil and oil filter. she gets 1.8 bar boost and is happy.
#12 ·
#20 ·
Selenia Oil is available at the dealers walk in and get it over the counter,the oil is specifically for the Multiair engines....have a look at the cans...
Why would you go and try other oils?????
I think we are well versed now to know how sensitive this MA is..
the sensor on the unit also picks up the viscosity of the oil..
You want to save R15k/R16k ??? use the correct oil..
#21 ·
It would be interesting to see what the oil guru's have to say. Certainly if two oils have the exact specifications they should in theory perform the same function? It is not about saving money, it is nice to know that there is alternatives available.
As far as I understand the oil change intervals are a bigger contributor to M/A failures than the specific oil itself. Even if you use Selenia, it would be insane to only change every oil every 30 000km.
#22 ·
One thing I know from owning Alfa is never trust the service advisors, they might be correct but best to research the subject yourself and do lots of asking around. Then make your own decision.
#24 ·
Question.....
I changed oil on my sister Mito with Shell Helix Ultra 5w40, which in my opinion is one of the best full synthetic oil you can buy. She has done less than 5000km/year. checked the oil last week... doesnt look if its dark at all. clean clean. Would you guys think i should maybe go back to Selina oil??
As for the dealers... Chatz put Castrol Magnatec in my 159 TBi @ 30 000kms. Probably the crapest oil you can put into any car. creates sludge and if you change to a different oil... BANG!!!!
#30 · (Edited)
Unfortunately the multiair engines and tbi engines are not bothered by opinions. They want the correct spec or they will break.
The Selenia oil has lubrication as well as consistent hydraulic properties (has to act as a hydraulic fluid with the exact same properties over a wide temperature range where normal engine oils experience changes in those properties which affect wear and performance of the multiair unit) as well as specific cleaning agents in order to work inside your engine.
It is wrong to brag about having clean oil in your engine after 5000km just as it would be wrong to take a bath and get out leaving the bath water clean. What exactly did you wash off? The better oils turn black very quickly after an oil change but continue to work while being black, and prevent formation of sludge or varnish. An oil remaining clean is not removing any dirt from the engine, neither is it combatting varnish which may be sealing impurities.
#26 ·
chatz have been using the Selenia in the blue 5 litre for some time now in the TBI.
