So the Mito has poorly badges. I've had some from car passion turn up. Is it really a case of piercing the badges and gently lifting the emblems off or is that a myth ??
I changed mine recently to black a white badges to match the car.So the Mito has poorly badges. I've had some from car passion turn up. Is it really a case of piercing the badges and gently lifting the emblems off or is that a myth ??
There are some past threads where there have been screws - did they change the design at some point?I changed mine recently to black a white badges to match the car.
there is no screw holding it on, it was a case of warming up with a dryer to help then pierce and ease off , remove any acess glue and replace , same with rear one.
mines a 2010 model if it helps...There are some past threads where there have been screws - did they change the design at some point?
http://www.alfaowner.com/Forum/alfa-mito/331909-how-to-change-the-alfa-romeo-front-badge.html
