1 - 11 of 11 Posts
Hi guys I know it's been discussed on here a lot, but maybe you can help me out. Yesterday evening I was driving the mito 09 1.4tb and it was raining quite heavily all of a sudden the check engine light came on with vdc asr hill holder and steering. And then the temp gauge dropped and the car fan started. I checked this morning and whenever I start the car everything pops up again and the engine fan goes on. Oil and water is all fine and car drives perfectly no limp mode at all
Any help
Sent from my ANE-LX1 using Tapatalk
Giulia Quadrifoglio Feb 2017 Alfa Rosso, Fiat 500e Apr 2021
Check your battery is the first thing i would do, and the alternator.
Should give more then 13,5volt when the engine is running.
Verstuurd vanaf mijn SM-G965F met Tapatalk
I agree that the battery being low is the most likely cause.
However, checking the voltage with the engine running is more a test of the alternator than of the battery.
Battery voltage with engine stopped is better, getting the battery properly tested is even better.
Andy
  • Like
Reactions: nick_dastardly
Voltages are good.
You said it rained heavy, maybe a short circuit somewhere because of that?
And you can test batteries with special equipment, amp cold start etc.
But i would keep an eye on it see if it stays away, does it happen again then i would search further.
Discussion Starter · #9 ·
Voltages are good.
The problem still the same, biggest worry is the engine fan that runs when the car start up non stop. I'm gonna check all fuses now
1 - 11 of 11 Posts
