Hi all. My Mito Lusso 1.4 is due a cam belt change - it's 2010 and 54000 on the clock so is a bit overdue. One garage has quoted £320 and one £550. The more expensive garage say this is a specialist job and requires the belt, tensioners and a variable timing unit plus the water pump and will take 3 1/2 hours and that £320 to them sounds unlikely to include all the recommended work. The cheaper place is Halffords and the more expensive is a small local garage I have used before but have no great affinity to. I'm in east London near Essex and dislike the local Fiat/Alfa dealer and garage so don't want to use them.
Other people here have had quotes under £300 so I am a little confused. Any guidance would be appreciated.
