First off, sorry if this topic has already been covered but I could only find a thread for the 4 cylinder cars and not the 2 cylinder models.
My local Alfa Specialist in Derby diagnosed my sons Mito misfire as a defective Multiair unit.
He sugessted that an oil flush may remedy the fault but if not, then it would probably need the Multiair unit. To cut a long story short, the oil flush just made the misfire worse so the garage has now changed the MU.
Unfortunately I got a call from the garage to tell me he'd replaced the MU but then couldn't get the car to start.
A few hours later, the garage called to tell me that they had finally got the car to start but the oil pressure light was on and the car was running rough.
The oil light does go out if he revs the car over 2500 rpm but then comes back on when in idle. He is reluctant to keep the car running until the oil reaches working temperature as he doesn't want to cause any damage.
I've read on other threads that other people have had the same problem and just continued to run the car until it ran ok but again, this was with the 4 cylinder model.
Has anyone had a similar issue with the 0.9 Twinair?
Many thanks
Many thanks
