hi can anyone help. my 156 1.8 t spark has had the the air filter disconnected and some one has fitted a k & n straight on to the maf could this be whats causing it to run so bad when cold ????
it seems that a few people on here have had the same problems from cold. i've tried the car with the sensor unplugged it runs slighty better but still has major drop off at low revs until warmed up.
try a new MAF !
p.s. sucking air from within the motor compartment is still a bad idea, air should come in as cold as possible....
thanks my intention is to put the original airbox and pipe back together but i cant seem to find one anywhere
I see them on Ebay all the time, even seen one lately with all the pipe work you need and it was dirt cheap.
Iv'e tried lots of diff induction and i found a modified stock setup is best.
