1 - 20 of 32 Posts
my mileometer has just started to only display parts of the numbers ?? this is also the same on the trip meter any ideas ?
Eric
mine done it too,been keeping an eye out for a cheap phase 2 speedo with the same sort of milage,but still no luck
You could get another working speedo and swap over the board that is on the back of the speedo.There is a chip on the board that stores the mileage for the car.
After removing the the binnacle from the car (2x M4 allen bolts on the binnacle above the speedo and tacho and 2 connectors with a push button release)
2x philips screws on the rear cover, undo these then un-clip the sides of the cover.
http://i246.photobucket.com/albums/gg92/explosive-alfa/cc3042de.jpg
pop the white plastic retainer holding the ribbon to the circuit board.
From this.
http://i246.photobucket.com/albums/gg92/explosive-alfa/85f4ca5c.jpg
To this.
http://i246.photobucket.com/albums/gg92/explosive-alfa/77301fdd.jpg
Now undo all the screws holding the circuit board to the binnacle and evenly pull the circuit board away from it and check both sides of the terminal faces of the ribbon cable for corrosion and if needed clean with fine emery cloth or fine wet n dry sand paper.
http://i246.photobucket.com/albums/gg92/explosive-alfa/d6998401.jpg
Now make sure the retainer is fully out or not falling off.
http://i246.photobucket.com/albums/gg92/explosive-alfa/96861b8c.jpg
Time for reassembly.
Push the circuit board back onto the binnacle and line up the ribbon at the same time, it's not as fiddly as it sounds.
Screw the circuit board back down. now making sure the ribbon is firmly in push the retainer back down.
Now slide the cover back onto it's guide rails covering the ribbon cable. and push down till all clips click back into place.
http://i246.photobucket.com/albums/gg92/explosive-alfa/9cbe5ee9.jpg
2 philips screws and it's all back together :D
Discussion Starter #20
well done all that and ......... it still does not work :-(
Looks like it needs mending with a fresh one
If anyone spots once can they message me ?
Thanks to everyone for thier suggestions
Eric
1 - 20 of 32 Posts
