21 - 27 of 27 Posts
Will do , its a very odd one as it only seems to happen when you pull away a bit aggressively, but will check the AC fluid as you suggest
thanks
I had a car with a very obvious metallic rattle that you could hear in low gear. Turned out to be a loose bracket on the front axle, but the mechanic was convinced initially it was to do with the catalytic converter. Might be something to consider.
I'd thought it might be this , but hopefully not , but with my luck it probably is
Hi try turning off everything radio heater put the car in neutral in a straight straight run if you here a roaring nose then it’s a wheel bearing only way to tell put each wheel individually up on a jack take the hand brake of and spin the wheel if it’s the bearing you will here the roaring nose and put hands on both ends of the wheel and rock it side to side if it rocks it the bearing hope this helps you delete that
21 - 27 of 27 Posts
