Hi
After "inadvertantly" resetting the factory defaults on the radio - my metablue system is so quiet as to be inaudible.
How do I reset or increase the default setting of volume and alert tones that come through the car speaker system on the metablue2. Its fitted to my 2006 159.
The beep that used to signal its connected to the phone (along with the led message on the radio display) is much quieter - if that gives any help to soloution
Thanks for any advice
Regards
Matt - brighton
There is a setting marked "Ext Volume" or some-such in the headunit menu.
Plenty of old threads on this.
You have to set it REALLY LOUD as the audio feed used to set it (CD or RADIO)
is much higher than that of a handsfree kits plumbed into the back of the HU.
Thanks Again
It worked a treat !
You were right - it needs to be up very loud to affect the default volume of the handsfree
Most grateful...
Matt Brighton
