Hi Gents, thanks for the posts. Managed to find the time today to check MES, Battery SOC @ 37% even though its recently had a CTEK charge and has been on a few runs so definitely need a new battery, Alternator putting out 14.4v so no problem here.
Had various errors intermittent detected no CEL, captured a log and have reset.. Will monitor this over the next few weeks/months. I also suspect all modules need updating even though according to the paperwork the dealer apparently does these when purchasing a car... More lies...
Is there anywhere I can check for latest firmware ect so I can confirm this and pressure the dealer?
current:
Engine / ECM
UNKNOWN/UNSUPPORTED
ISO Code: 00 01 50 43 18
Hardware number: MM10JAHW232 - Ver: 00
Software number: G543BA8A - Ver: 0000
Gearbox / TCM/NCA/NCR (Automatic Transmission)
ZF 8HP50/75 Automatic Gearbox
ISO Code: 00 0B 50 AA 14
Hardware number: 10344202761 - Ver: 20
Software number: GK0901OD2FW - Ver: 0012
Gearbox / ESM/GSM/NSC (Gearbox Selector Module)
ZF Electronic Gear Shift Module
ISO Code: 00 16 50 B4 14
Hardware number: 1000597140 - Ver: 08
Software number: 1000678050 - Ver: 0019
Body / BCM (Body Computer Module)
Body Computer Marelli (952)
ISO Code: 00 00 50 5D 14
Hardware number: BCM952M_D01 - Ver: 03
Software number: 04441660381 - Ver: 0706
Body / RFHUB (Radio Frequency Hub Module)
Radio frequency hub (RFHUB) Continental
ISO Code: 00 41 50 BE 14
Hardware number: 97655601AA - Ver: 01
Software number: 10307064AB - Ver: 0760
Dashboard / IPC (Instrument Panel Cluster)
Instrument Panel Continental
ISO Code: 00 03 50 8B 14
Hardware number: A2C11140400 - Ver: 01
Software number: AR952 HL - Ver: 191A
Other / DASM (Driver Assistant System Module)
Driver assistant system module (DASM) radar Bosch
ISO Code: 00 39 50 15 15
Hardware number: MRR1evo14F - Ver: 00
Software number: 52083414 - Ver: 0902
Out of curiosity anyone ever seen the below errors?
Engine / ECM
Errors found:
P2BC1-00
U1008-00
Errors found:
U1746-86 - Lost communication with Audio Amplifier module - Signal/message invalid
Errors found:
B1040-64 - Communication with Body Computer (BCM/NBC) - Signal/message plausibility
Errors found:
B1029-64 - Lost communication with Steering module (SCM) - Signal/message plausibility
B102E-64 - Communication with Body Computer (BCM/NBC) - Signal/message plausibility
U1736-86 - Convergence Telematic Node (NCV) - Signal/message invalid
U1736-87 - Convergence Telematic Node (NCV) - Missing message
U1757-87 - Drive assistant system module (DASM) - Missing message
B1000-47 - Control unit fault - Watchdog/safety failure
Anyways, have a great Christmas/Festive period all and stay safe.
