You won't see a blown fuse..... At most, because an ecu gets no power, you will be unable to read that ecuProblem 1: Selespeed pump fuses are blowing
– the blown fuse for the pump doesn't show up in MES
– relay looks ok in MES (removed it just to see if MES is reading it)
Problem 2: the car won't start. (Battery is good.) Knowing that the brake pedal sensor can have a hand in this, I (a) "actuated" the brake lights (they work), I (b) stepped on the brake pedal (the lights go on but, interestingly, MES>Body>Paraeters>Brake lights remain OFF).
I'm thinking that I should check the ignition fuse (F72 on top of the battery), but (a) as it appears to be bolted in, and (b) I've yet to become familiar with this type of fuse and I'm not sure what I'll find when I get it out, I'm thinking that the easy way is to look in MES, but: Do blown fuses show up as errors in MES?
