I have a friend who took his Spider to John in Belfast for a cambelt change, he instructed him to change all belts and tensioners and variator. He took the day of work and went shopping, returned at closing time and was told that the belts had been changed as was the waterpump but the tensioners where fine as was Variator. Thought this sounded decent payed him over £300 and drove his car home in dark. Next day went and inspected the car and the belts he was given that where taken of his car. The belts where not from his car and the water pump had been changed but the balance belt and cambelt where not new only the Aux belt had been changed!:wow:
:tut:
Further, the top cover for the belts had been bent back and was no longer sitting tight against the block! So! it would appear that he could'nt even be bothered to undo the screws to examine the cam & balance belts. Upon looking in wheel arch he discovered that the lower cambelt cover was not put back on and the wheel arch cover was missing also!
He was told also that his variator was fine and did not need changing even though he had requested it as it was the 2nd belt change. A month later, he began hearing the Diesel sound on startup!!!!!!!!!
I would advise to avoid Eurofix also!:tut:
