I will start off with a bit of background.
I collected my 2.0 52 plate 147 on the 16th of Dec. As an Alfa approved used car it came with driveline 3 warranty cover.
On the 16th of Jan the clutch stuck to the floor while I was driving. Got the AA out and he thought it was hydraulics so towed me to garage and car I left with them. Now the clutch wasn't completely stuck to the floor I could use my hand to lift it up and then it would stay high. No resistance inbetween was like a switch. I did check the level for the fluid and it seemed to be fine so there was no dramatic leak as far as I could tell.
Garage phoned me yesterday afternoon to tell me it is not covered by warranty quoting £6** (after the six hundred I stopped listening)! The parts they told me were 1 master cylinder '1 sleeve' as it was described and then the fluid on top. Labour was £428 + VAT!
After my investigations what was described to me as a sleeve didn't match up with the part number they gave me which was a thrust bearing according to everywhere I looked.
So I phoned them about that he says he will check. Calls me back says to forget that part and the labour is ?3 hours? so the total is now £470 if I have it done.
£470 bill for a car I have had for 1 month which is under alfa warranty!
I was hoping it would be the clip on the back of the pedal, no such luck...
