If you could mate that would be great. :thumbs:symon, i still have my defunct original ariel in my shed, if you like i can bring it to the world record attempt so you could butcher it for parts or just use it as a dummy run to see what is inside? let me know and i'll chuck it in the boot. :thumbs:
I have already tried that.Both my gtvs were the same when I bought them, spray the old one with WD40 then clean all the black crud off and it should work fine .
What make is the internal one, does it work well?Our Maplins one got slightly bent (it is quite a bit longer than OE) then burnt the motor out.
It seemed ok but we went for an internal one in the rear window to solve the problem.
Fit a bung usually, but cos its my Alfa and i get all emotional about it i'll probably fill the hole and spray it so as u'd never know it had been there.If you use an internal Aerial what do you do with the hole left by the electric one?
