car does roll in nutral.engine turns over
as the clutch is let out the car will stall
with the car turned off all the gears can be selected.
have I got a problem that needs the gearbox out, and what are the steps!
the car used to start in neutral with the clutch out but now it seems jammed.I wont do it cause it will jam up or make a crashing noise.
...I suspect it is something to do with the throw out...
car starts in any gear.Okay engine off. Put into first geat. Clutch down. Start engine. What happens?
its the 2ltr petrol engineApart from it being a manual box 147, we haven't got much info to go on.
Which engine is it?
thanks,,,,is there any way I can confjrm this before I start ripping into it?Sounds like the fingers from the pressure plate are starting to come off.
You'll need a new clutch.
Well it is gearbox related and you'll see the clutch when the gearbox comes out.thanks,,,,is there any way I can confirm this before I start ripping into it?
