1 - 16 of 16 Posts
After using Novitec Pwerjet 2 for a long time , I decided to try Magneti's MM110T box.
It has 3 different map setups. 0 for default map , 1 for sport and 2 for race . Modes can be changed via wireless remote controller.
It has a usb port and can be programmed by authorised dealer via teamwiever online. Yes you plug it into your computer and let the dealer do the rest. I got my race mode programmed again for max settings.Authorised dealer can change the parametres between the limits of Magneti Marelli tech.
After the Alfa's infamous GQV software update Novitec didn't work the way it was before . Magneti MM100T is a very good product. Using it for 3 months and I'm happy with dynamic + race mode
LISTA CENTRALINE TURBO BENZINA
http://i.imgur.com/BaROpiB.jpg
http://i.imgur.com/8cgTRsx.jpg
http://i.imgur.com/rJewngz.jpg
i have my 170 diesel remapped, best thing i ever did to a diesel it's a completely different car.
I would reccomend a remap to anyone wanting to transform their car.
They do, its called a tuning box. I keep the required tools to remove mine in the glove box, only a t20 driver. I can whip it off in 2 mins.
Then if any problems take it back.
knowing my luck the fault will be that the bonnet wont open or I'll wreck the front of the car and can't get access to it annoying both alfa and my insurer :p
R
Speak to Gus at Alfatune in St Helens about remaps he has the best maps around for your Alfa and is not far from you.
Where did you have it done?
I had mine done in yorkshire by an engine builder that i quite often do flocking jobs for. he does a lot of time attack cars and has a rolling road.
If it's of interest in normal mode i achieved 208bhp, not sure what dynamic is because it would'nt stay in that mode on the rolling road due to the abs kicking off but it's a massive difference to the standard setting.
I also had the EGR mapped out, cost me £240 including the power runs.
Amazing, I might talk to you again in a few months when my warranty is up to inquire about it.
1 - 16 of 16 Posts
