1 - 20 of 25 Posts
I got a replacement Bosch MAF for my 156, as it was going cheap and i thought it would be worth keeping just in case.
Problem is, when it turned up, it has a different plug fitment to the one that is already on there.
Now i am having a few symptoms that are making me think my old MAF is on its way out, but i cant do a straight swap. Is there any way of just swapping the internals over? I wanted to ask on here first before completelydestroying the one thats on there and maybe even killing my replacement without even fitting it :confused:
Am not aware of any plug changes :confused:
No way the internal could be switched AFAIK, the back of the sensor is where the plug fits...
Deffo like for like unit, ie part numbers?
D
Which 156 do you have ie ts, jtd etc
and what is the part numbers from both MAFs, sounds like you may have been sent the wrong one tbh
Not good sounds like it is not the correct one for the car,I knowtheir are various mafs that cross over makes.
Have a search on here for threads to do with mafs and i think that will help you.
Good luck
Did my 2.5 recently put a maf off a omega 2.5 onto it and it did the trick even though the no on the maf were different! It cost me nothing so there was nothing to lose!
L
sounds like you got a MAF for either a 155 or Ph1 GTV. What engine is your 156? My advise would be to return it & buy the correct MAF.
L
"ALFA ROMEO 145 155 156 1.6 16v T SPARK MAF MASS AIR FLOW SENSOR METER 0280217111"
its false/bad advertising. 145/146/155 using the 4 position connector, 156/147/166 use 5 pin connectors. Anyone selling MAF's should know this.
Return it ASAP asking for the correct type for your 156 car. If that doesn't work then 'Open a Dispute' with the seller
L
Discussion Starter #14
I guess you can see how i made the mistake then :(
to be fair, it is like brand new, and it was the price that swayed it for me, just a shame its the wrong one :cry:
this one is what you should have bought http://www.ebay.co.uk/itm/ALFA-ROMEO-156-1-6-TS-16V-00-01-117bhp-BOSCH-MASS-AIR-FLOW-METER-MAF-0281002309-/180731747272?_trksid=p4340.m185&_trkparms=algo=DLSL%2BSIC.NPJS&its=I&itu=UCI%2BUA&otn=10&pmod=260850988302%2B260850988302&po=&ps=63&clkid=4427785383159296589 yet another ebay mis info ......[/QUOTE
but he'll be down 3hp :cheese:
"ALFA ROMEO 156 1.6 TS 16V 00-01 117bhp BOSCH MASS AIR FLOW METER MAF 0281002309"
:cheese: hot day when they tested them:cheese:
L
its no use to you, return it or sell it. those are your choices.
Discussion Starter #17
Can i still do that as its a few weeks since i bought it?
I should have checked sooner really but just assumed it was the same. Even when i opened it up and looked at it, i didnt realise until i had actually tried to plug the wire into it...
L
afaik you have a month or so to open a dispute BUT first you must enter into correspondence with the seller. Be polite but firm, asking for them to exchange it for the correct one, quote the part number you require.
1 - 20 of 25 Posts
