1 - 18 of 18 Posts
Depends on year and engine...
Is it a CF2 TS or a CF3 TS or a 2.0JTS or even a 3.2v6 ...?
Its the 2.0ts fly by wire motor so CF3 i believe 2000 plate.
ALL Selespeeds are fly-by-wire, so you can't use that to know if it is a CF2 or CF3.
The change-over was from Sept 2000 Build in Europe.
D
They quite often fail without showing up on diagnostics.
What symptoms do you have ?
Not uncommon for them to make the car feel really sluggish. Try disconnecting and taking the car for a drive.
The engine management light will come on and it might not idle but see if there is any improvement when driving.
I was concerned about fuel consumption and performance. FES showed an Oxy Sensor fault so replaced that and the sparkies too. There does seem to be a little improvement (although not sure on mpg).
Usual MAF failure symptom is the inability to pass 5000rpm under load and it will only pass 5000rpm using very light throttle.
Discussion Starter #14
I think it maybe my car not reaching the correct temperature. My car runs at around 70-75 degrees, Europarts say their new thermostats open at 88.
I'm sure I saw a discount code on here for Europarts ;)
I'm a cheap skate lol
Does it sit at 90 in traffic?
90 is where it should be all the time once warmed up (which shouldn't take long).
1 - 18 of 18 Posts
