I need some advice regarding my Sporttronic which has a low and lumpy idle when warm, doesn't pull clean from low rpm. I just doesn't feel right. When the car is started from cold it has a lovely steady idle at around 900 rpm and when giving it the boot it pulls clean without any hesitation all the way through the rpm range. Sometimes it can leave a misfire cylinder 1 error code when pushed really hard (but not in a while).
Things checked so far:
ECU-resetted (a few times)
Timing checked with correct cam locks
Lambdas disconnected (throws an error but doesn't affect idle)
New MAF fitted (runs smoother but not smooth enough)
New NGK sparkplugs fitted
Coils switched without any change
Sprayed for air leaks using start gas to no avail
Changed throttle body
So any pointers to what I should be upsetting the wife by doing next?
