theres some alfa 33/sprint springs (late sprint, with out board brakes) on ebay now which are listed as 905 if this narrows it down a bit....
as far as i know there are basically two types of front spring, (inboard sud/early sprint) and (out board late sprint/33) and it seems even the manufacturers get these mixed up...
in my experience a lot of the aftermarket sud lowering springs are different to the original spring (ie the front spring doesn't start and end in the same place as the original when you look down/through it) turn the spring so the top end closest to you is at 12 oclock...
....... 33/late sprint springs starts and ends in the same place "12 oclock"
....... sud/early sprint springs starts at 12 and end at quater past (i.e. theres a 1/4 turn missing)
iv tried avo sud springs and theyr the same as 33's, i sent them back as i couldn't get the sud to sit right on them without cutting 1/4 turn off the end (3 to 4 inch maybe)...
The only springs iv heard that fit exactly are the justsuds springs, ( i had a good chat to the previous owner and he explained it to me when i was having problems fitting the avo's)
one of the lads iv spoken to at alfa meets tried various set ups on his sud, he found the justsuds springs to be the best...
hope this helps, if not a little confusing
and if anyone can add to this i'd be interested to hear what other people have tried, im about to try some near new spax i bought cheap, although they are specifically for a sud ill probably have to cut them slightly... ill check on the box today and see if they come with a number (902 etc)
if it doesn't ride properely on them then im going for a coil over kit (about £75)
http://www.rallydesign.co.uk compared to about double that for justsud springs!!
