1 - 20 of 32 Posts
My car wears 18" wheels which look great, but on the standard suspension set up the car rides too high on them and doesn't look quite right. If the car just sat a little lower then the wheels would fill the arches perfectly.
I am curious about whether a 20mm drop might cure this but am concerned about messing with the suspension as currently the car handles brilliantly and doesn't even feel that unsettled despite the large wheels. Also one of my previous cars of years gone by was lowered on Tein coilovers and handled terribley.
Have any GT owners with bigger wheels gone for a drop? What was the result?
My mantra has always been that a £200 set of springs off Ebay are unlikely to improve on hundreds of hours of development time at the hands of qualified development engineers.
The ride height is bugging me though.
Any thoughts or experience people? :confused:
+1 for Eibach.
Had a chat with Nigel at Angel Tuning earlier who reckons just the Eibachs should make a big difference to handling without the need for better damping. Reckoned the ride wouldn't be too affected either.
Will look into this I think! Thanks guys.
Would you all give the same advice for lowering a 3.2 V6 GT ?
As I understand it the 3.2 V6 already sits slightly lower than other GTs.
Do Eibach make a specific kit for the 3.2 V6 GT ?
they will have different spring weights due to engine weights etc...
Exactly tomfromtelford and therefore if they produce one kit for all GTs then this may be good for some engine types but may not be good for others. 3.2 V6s are definately lower than other GTs to start with, so has anyone had any experience of lowering a 3.2 V6 GT ?
there is an Eibach Pro Kit for the 3.2L. however, the front does not lower significantly. as above, it is because the V6 is already relatively low compared with other models.
however, i wasn't satisfied with this lack of drop at the front, of only about 2mm when i did before/after measurements. even allowing for some sag over time, it would only have ended up about 7mm, i'm sure. rear did drop nicely, by about 30mm.
i had my setup modified. my local KONI distributor (i'm in Oz) modified the damper-suspension fork join. this allowed the damper to 'fit in further' into the fork, resulting in lowering the car, without altering the Eibach spring. overall, i have about a 17mm drop from the original.
this confirms the V6 is already low, because the undertray can scrape the road if i go over a decent dip. doesn't bother me; i drive with this in mind. in general, not an issue cos it rarely happens.
i don't think there's a better set of springs. but if you want the front lower, be prepared to modify things.
*modified damper-fork join:
http://pic20.picturetrail.com/VOL97/467659/18994705/302919615.jpg
*unmodified, Eibach fitted:
http://pic20.picturetrail.com/VOL97/467659/12212732/189968067.jpg
http://pic20.picturetrail.com/VOL97/467659/12212732/242548863.jpg
*more recent, after modifying damper-fork, and time for sag, totalling in ~17mm front drop:
http://pic20.picturetrail.com/VOL97/467659/18994705/317356862.jpg
James, did you do the eibach 30mm spring? i am curious to know if your ride quality has changed? i am also worried that i will lose ride quality and harshen the ride of my GT Jtdm
Discussion Starter #16
Hi buddy,
Sorry for late response!
Not done the lowering thing yet - reversed my car into a concrete post and the repair bill kind of put my mod shopping list on hold! :eek:
I definitely want to lower the car but having read a lot on the subject I will not do so until i can afford the Eibach springs and the Koni FSD suspension. Judging by how crap the standard dampers are on my car and in light of common experience on the forum, there is no way I am fitting shorter stiffer springs without sorting out the damping at the same time!
I have some other things I want to do first, namely brakes and power, so it will probably be some time before I can sort my suspension out.
Let me know how you get on though if you fit the Eibachs - would be very interested to hear your feedback.
JJ :thumbs:
Hi buddy,
JJ :thumbs:
Hi James
I fitted the eibach 30mm spring kit on my alfa 147 the ride is now very firm with no body roll. I mut admit that i lost allot of comfort. now i am scared to do this with my GT!
S
Hi James
Hey fella, I fitted Eibach 30mm springs and Bilstein B8 Sprint shocks and its fantastic, looks great as well :D
Plus its even less bodyroll than just the springs :thumbs:
Im considering lowering my GT very soon aswell. But I wont be buying eibachs they just dont sit lower enuff for me. Has anyone bought H&R Springs or Novitec?
1 - 20 of 32 Posts
