I have had a Low Battery Power warning come up and thinking it was caused by the ill fitting positive clamp, I made a better connection. However after having done so, I had the warning again. As I've fairly recently bought the vehicle, I don't know how old the battery is, so is it possible that a failing battery could cause the warning?
Terry
Have you got a basic electrical multimeter to check the battery voltage?
12.2V is officially a flat battery.
12.6V or more is what you really want to see at the terminals.
I don't know what triggers the warning on a 147. On some it is triggered by the alternator output being too low rather than the battery voltage being too low.
Thanks David, I looked through the old invoices that came with the car and found that it had an alternator fitted in 2017, so hopefully that's ok.
I have a multi meter so I'll check.
Terry
2004 Alfa Romeo 156 1.8TS
The 12.6V is with the car off.
Mine is always above 14V when charging (so engine running). Alternator is half a year old.
