I have lost some clutch pressure after a long run in hot weather once the engine bay cools down a bit. I had a problem with my master cylinder seals leaking so maybe your problem is also master cylinder related. Have a look to see if you can find any oil dripping off the master cylinder in the foot well area (it doesn't take much).
To counteract my problem after I reconditioned the master cylinder I put a heat shield over it.
If you haven't changed your clutch/brake fluid for a while, maybe start with that.
Other than the fluid or the master cylinder it could be your slave cylinder or something else I haven't mentioned.
Good luck finding a solution; I know clutch problems are annoying.
I know this is an old thread but how did you recondition your Master Cylinder MGG -If you're still on the forum-.I've been able to buy a seal kit for the master cylinders on every bike I've ever owned and for brake calipers on a fair few cars but don't know anyone that lists one for the 156 or GT clutch master cylinder.
