Hey everyone, this is probably the last place I can visit for advice because I am running out of options, hope you don't mind
Anyways... I used to have pretty much the same alfa before, only thing I ever changed was intercooler and some maintanance before losing her.
I bought another one dirty cheap and it has already cost me some money fixing the aux belt and stuff around (alternator pulley turned both ways, tensioner belt holding on with hopes and prayers etc.)
And I am having a new issues...
First problem is losing coolant/extremely overheating, I drive with diagnostics on all the time and the water temp is around 70-80 Celsius, but the moment I go uphill it goes up to 120 no problem and starts boiling and going everywhere around the reservoir... I also noticed the coolant flowing immediately after I start the car (also it can idle for 10-15 minutes and still stay on 60-70 celsius)
Which I find more than weird and thought it can be a bad thermostat but don't want to spend any more money than needed since I only buy original parts like BEHR etc
Second problem is this hose coming into the oil catch can, it is completely loose, not problem lifting it and probably the reason why everything around is so dirty, is there a clamp of some sort that holds it?
Thank you in advance
