Hi guy's, i've just noticed that i'm loosing coolant fluid from expansion bottle, i've checked all over for any leaks but can't seem to find any, had car upto running tempreture and got pressure in system but can't see any leaks from anywhere at all, anyone got any idea's or am i missing something simple, need a little help please, cheers
unscrew the expansion bottle and check for cracks. I had a little one in mine today and its solved with a little epoxy till i source for replacement.
It could be a slow drip. Top it up and check after each drive?
I would say check the coolant fluid reservoir. At least at MiTos one encounter the reservoir leaking due to minimal cracks inside the connections to the cooling systems. It´s a rather common issue at Grande Puntos too. Don´t know if Giuliettas are affected too, though. Just a guess.
