Hi all question, I have a loose hazard/locking button. I've managed to get stereo out remove cradle etc, but no can't see how to take the vent bezel off to repair the switch any help ???
Hi. If you look underneath the vent bezel,you will see 2 screws [ torx head] Remove them the air vent facia is held on by 2 more above the airvents and a push fit spring clip at each side.Slowly leaver the bottom of the panel forwards.When loose give it a good tug and the air vents will unclip themselves. Ounce they are out remove the top screws, The swith is help in place by 2 self tappers screwed into plastic lugs. It is a right faf,but I hope this helps.
ace, i knew it wouldn't super straight forward
. Cheers!!!
