Has anyone got Alfadiag or Ecuscan working on a Surface tablet?
Please note this is not if it should, but actually done - all I'm getting is .net requirements but Surface reporting it has the requisite components. So a true chicken and egg.
Can't delete and reinstall - embedded into registry
Can't install over - your existing version already contains this element
Can't install diagnostic without it - Stuck, stuck stuck!
Any experienced guidance appreciated.
If you want to completely remove the install run a system restore to a date/time before the initial install. If you are feeling brave you could then try the install again.....
Does the software run in Windows 8?
Have you tried running it in compatibility mode if possible?
I am sure system requirements would explain this on their site
