Anyone know an sensible way of locking the cams on a Q4 head? - I've been told to hammer a block of wood in between the cam wheels - I need to replace the camshaft oil seals & they've tightened them up FT.
cheers,
A
Discussion Starter · #2 ·
use the old timing belt and wrap it around both wheels and then wrap it round something to hold it in place. :D
F2G Have you took the rocker cover off and had a look at the Camshafts 99%of camshafts have either a six sided section or a flat between the lobes that you can get a spanner on to hold it
Think they are used for assembling and turning the cams into the right position for setting up
Discussion Starter · #6 ·
F2G
this guy rents out a cam wheel locking tool (note not cam locks) for £8 a week £77 deposit and postage £3 his name is [email protected] and he advertise's in the Thema Dedra Consortium Mag
Hope this helps
Ted
Discussion Starter · #7 ·
Hiya SpeedF - they don't have the flat's the alfa cams have :(
Nordic.. Cheers.. I might follow that up..
I've been told an air impact gun should do the trick..
A
