I have a PH2 spider and air con is not blowing cold air. It was recharged last year and the compressor is working when 12v is fed to it. When air con switch is on, there is no power to the wire which connects to the compressor, so I am now on the hunt for an electrical fault. I have located and checked fuses but can't find relay referred to in workshop manual which is Q22. It says: 'grouped in the engine compartment, next to those of the ignition/injection unit'.
I can find the ignition fuses but no sign of Q22! Does anyone know where it is and are there any other relays/connections I should be checking?
