I can move the mirror by hand about 5 - 10 mill so something is worn , as I've never took one to pieces is it possible to fix it ?
Brera TBi
Mine also have this issue, worse on one side than the other, when driving the whole mirror wobble about. The side which is worse is also cracked so I suspect it's just taken a knock a large knock at some point and damaged the mechanism.
Unfortunately I think the only fix is a new mirror, as I can't seem to find an obvious way of getting access to the powerfolding hinge...
Remove the mirror from the car... You can then disassemble the mirror quite easily. Tilt the glass forwards / downwards and get a plastic tool in the gap and gently prise it so the glass pops off. You will see the screws that you need to remove and then the whole electric unit can be removed from the mirror housing. Make sure you pop the temperature sensor out at the same time as thats connected to the same unit (if its the drivers side)
