341 - 352 of 352 Posts
Finding out you already have Auto High Beam after owning the car from new for over 2 yrs
You have to push forward the light stalk to activate it ... if the car is already equipped with it
I think "most" can have it activated using MES, don't know if I can justify buying MES just for that (and activating ACC)
That’s how I discovered that I already had it via MES. I was going in to enable it and it was already enabled.
Nic ... MES is Multiecuscan
How can you tell of the car has it? Something in the options menu?
No, in the Can Set Up / proxi alignment section of the Body menu of MES it was showing as being present.
This pic is from Multiecuscan app in simulation mode, same principle though.
MG has done a good write up on how to enable it, somewhere recently on the forum.
I don't have MES unfortunately, was just wondering if I could see of I have it without blinding people with my full beams
New one on me - if you are using the sat nav with a route (rather than just as a rolling map) I've only just realised that when the bit down the right hand side turns yellow/red it's because you are exceeding the speed limit (yellow by a little, red by a lot) and there is a speed camera coming up...
