I've been scouring the forum for answers to the LH indicator front and side not working and it seems to be fairly common without anyone posting their fix.
I've just spent an hour in the wiring diagram and if your indicators work for the remote central locking and alarm but not hazards or indicator it's the feed out of the fuse box G1.
The wire that feeds the LH front indicator and the side repeater is connector I pin 10.
Hope this helps anyone that has this or a similar fault on the RH side.
Has anyone fixed this fault by taking a feed from the fuse box output to the rear indicator and splicing it to the front wire ( I 10)
Thanks in advance
Tom
Discussion Starter · #2 ·
Dunno if anyone else had this but solved by dropping fusebox and properly connecting connector I into the top of it :)
