I know that I've seen something about this before but I can't remember where, but here go's, I have this leak from the sump plug is there a modification I can make or should I change the sump as I've been given a sump by my local dealer, it's off a late GTV :confused: and seems to be missing a hole on the extended piece at the back,
it also has a longer sump plug. Is a sump change a straight forward change or a bit more complicated.
J
if it has the longer sump plug then just change that dont bother trying to change the whole sump.the longer plug with a new washer might just stop it leaking.
