1 - 1 of 1 Posts
I've done mine. As Jim suggests makes sense (unlesss they have already been done recently) to change the UJs and the bearing carrier whilst you have the prop off. Make sure you mark the relationship of the prop to the flanges then should not need balancing when you re-assemble. Easy enough job to do, although you will probably need to get the old centre bearing pressed off and the new one back on. I certainly did!
1 - 1 of 1 Posts
