1 - 10 of 10 Posts
The little light that illuminates the mileage readout on my 2001 156 has gone pop. How easy or otherwise is it to change? Is it a dash out job or can I get access to it by undoing the screw inside the top of the speedo binnacle?
The same has just happaned to my car. does anyone at all know if it is easy to fix or if it can be fixed.
I would imagine you only need to undo the screw in the speedo housing to draw the dial forwards, gaining access to the unit behind... but this is not a job I have done, just a view based on what I imagine what would be the case.
remove the speedo & replace the bulb behind the LCD section.
1.2w capless is the bulb type, the old bulb can be removed from the holder
did that many times 5minute job !!! 1 screw and take the dial out
^^^^ 1 for bezel, 2 for dial, 3 total ^^^^
Just done it :cool:
1 screw to take plastic surround bit off, undo 2 screws holding clock in, remove clock, remove 2 plugs on the back of clock, take offending bulb out, replace bulb, put plugs back in, put clock back and put 2 screws back, put plastic surround in and the screw - 5 mins to do.
cheers guys :)
1 - 10 of 10 Posts
