Hi, I have just purchashed a lancia dedra 1.6 ie 1994 model. just wondering if any one knows of a fault with the front interior light? checked bulbs, fuses and connections to lamp hwever still doesnt work on button or when front doors open. has anyone else had a problem or know of a commom fault? many thanks
You could try the PIN switch on the door, they can fail or have a bad earth causing the light not to come on when the door opens but saying that the light switch in the car should still work. The PIN switch failed on a Golf i had and the interior light stopped working, one check if your car has this is a lights left on buzzer, leave the lights on and open the door with the ingnition off, if it does not buzz then it might be the PIN switch. Hope this helps
