1 - 9 of 9 Posts
Guys,
I'm working out what I need for replacing the lambda on my 156 V6. It has just the one lambda (near the catalyst).
I have the new part and it seems like a straightforward enough thing to do but I'm just wondering if I need to take apart any of the exhaust piping (saw you needed to do this in another thread for the 166)?
cheers
Gav.
0
Nope - some cut the cable to enable the use of a ring spanner though
Attach a piece sring to the connector end before removing completely to enable you to pull the new cable up :)
Neat idea with the string, thanks! :thumbs:
22mm spanner
flat headed screw driver to open connector & clips, possible remove the air intake pipe from airbox to throttle body to gain better access to the 2 or 3 clips at the back of the engine
string & 'insulting' tape to aid fittting the new sensors wiring,
rem to drop the cable down before opening the sensor & fit sensor before pulling wiring up.....saves the risk of damaging cables
Or you could buy a proper lambda socket ... Draper 55540 ... some on ebay for under a tenner.
why? sure aren't visegrips & a slap of a haamer good enuff for ya!!!:cheese:
Perfectionist! :)
Or sad James May type who has most of his toolkit hanging on the wall ... sockets all in order on socket bars, etc. :eek:
Plus I'm convinced it will fail again soon ... and I've got two other cars I run/look after ...
Thanks again guys. On the list to do at the weekend!
Hopefully after this she will be running 100%. In the last few months since I bought it I've replaced:
-Thermostat
-MAF
-Sparks
-All front & rear bushes & arms
It's been a steep DIY learning curve! Great to have this website for help though.:)
Gav.
1 - 9 of 9 Posts
