Hi again!
This time I need to talk about the lambda sensor in my 33. I need some advice as I think it might need replaced...
I replaced mine about 2 years ago with one manufactured in Germany (bought online).
I also have an Air/Fuel ratio gauge to monitor it, even thou I know it's not very accurate as the wide band ones. Anyway, apart the spectacular light show at night time
, you also get some readings. when recently replaced it used to heat up quickly and show readings 5-8 minutes after starting the engine. Now takes a lot more time to show something...
It used to start from lean until reached optimum values, only under hard accelerations could show rich and then back to optimum. (some people say that when just started the engine, it should show rich and than gradually go to optimum, but this never happened even when it was just replaced. It always did the opposite way, started with lean and then to optimum???)
Lately it is showing only lean and I thought it could be my KN air filter that needed clean. Cleaned it but this didn't cure it this time. Also in the highway it's not showing optimum, it just stays to the lean side.
Anyway I'm not experiencing rough idle, misfiring, hesitating, even thou I have noticed an increase of the fuel consumption.
Please can someone tell me how can I verify if it needs replacing again or what?
What do you guys think. If you need to know more about, to get to a conclusion just ask me.
Thanks in advance
Elvis
Thanks in advance
Elvis
