1 - 15 of 15 Posts
hi chaps i had my car 1.8 16v on the nostics machine on sat and the lambda sensor looks like its on its way . how much for a new one , i replaced it about a year ago from main agent for £120 isnt there another one that upgrades the old one . if any one has a part num id be gratefull ,any idea what could cause this as there must be a cause of them failing i know the heater element fails on some .
thanks Craig.xxx eek!
Banned
Hi fletch
I'm taking the old girl in on Thursday for service, variator & possibly lambda sensor (suspected on the way out cos i've had a bit of jerky running and injector light coming on). Taking it to specialist who has quoted £68 for a new sensor.
hi stu be aware there is an other lambda that is cheap but does not have right connection you have to cut and solder on not so keen on that though ! cmon j:b lets have it then ? :D
J
ok then £90+vat from alfa and about £40-70 non genuine depending on what type it is. :)
j:b is there an upgraded one to your knowledge i think i heard about it a while ago
maybe i should look on old pages methinks?
tah anyway does your fiat have similar probs or is it saved just for the alfas. :D
J
well it doesnt effect the fiats half as much....in fact i cant remember the last one i did..i have heard of the upgrade as well but cant remember who does it.
thanks any way j:b it must be a bit of a bore answering the same old questions all the time .
W
As far as I know Alfa will supply you with the upgraded one, best ask first though.
I had a lambda sensor fitted from a non-dealer source. To be honest after the non-origonal temp sensor problem experienced by one of our members I would only buy origonal sensors in future. They may cost more but at least you know its the right job. Unless you find out the manufacturer and buy the same elsewhere of course!
wrinx
W
While we're on this, why do the damn things fail so often???
Had four on my twinny and one after owning the V6 for only two weeks. Unless its my driving style there is something very wrong here.
I have two theories:
1-my Alfa's only just get through the emissions test, perhaps this means the exhaust gases are too rich, killing the sensor.
2-The position of the sensor is allowing it to get too hot or suffer from ravages of the road.
Are the FIAT sensor place the same??
Any other theories?
wrinx
Discussion Starter #14
Thanks guys for all the info ,i think i have to do a bit of research now .Wrinx ithink your right about why they keep goin i had my car tested just for the sake of it and found the sensor fault its just not fair booh hoo!. frown
M
My probe cost about £70 inc. VAT from the main dealer. £120 sounds a bit steep.
Marlon
1 - 15 of 15 Posts
