1 - 2 of 2 Posts
Hi All,
I am thinking of putting KONI shocks and springs on my GTV ........... I'd like some advice please..........
I can buy a set on the bay for £ 529.90 less a 10% voucher I have brings it to Just over £476.00
http://cgi.ebay.co.uk/KONI-SUSPENSION-KIT-ALFA-GTV-ADJUSTABLE-SHOCKS-SPRING_W0QQitemZ150300062284QQcmdZViewItemQQptZUK_CarsParts_Vehicles_CarParts_SM?hash=item150300062284&_trksid=p3286.c0.m14&_trkparms=72:1683|66:2|65:12|39:1|240:1318|301:0|293:1|294:50
Questions.............
Are Koni any good ......??
These are going to lower it a bit........... Good /bad idea ????
Am I going to achie anything with these ???? ............... What I'm really after is a little less of a crashy ride........... I'm told that gas shocks will help some.......
Will these fit on the standard springs ???? ......... If I decide not to lower it ???
Any advice here is most welcome...............
Cheers to All
Peter
If you are just after a more comfy ride with better handling, a set of bilstein B6 dampers on the standard springs would work nicely.
They aint cheap though, you will be looking at around £600 for a set.
Using the standard springs on different dampers will keep the car the same ride height as the the springs control that.
On those Koni's I am not sure they would work with the standard springs, as the spring mountings may be different.
I have Bilstein B6 dampers fitted to my coupe with lowering springs. Handling is much better, but ride is still ok.
1 - 2 of 2 Posts
