1 - 9 of 9 Posts
there a knocking noise comming from under the car but only does it when i ease off on the throttol!
i've checked the bushers and thay are fine! i've checked the exhauset and thats fine! had the car on the ramps, checked underneath and i can not find anything lose!!!
has anyone ever expereance this problem????
only thing i can think of is either anti roll bar or engine mounts!
just thinking if its safe anouth to drive to duxford and back from north wales!
Hi Andy, my V6 has the same problem, have replaced an engine mount, still there... then replaced front tyres, seemed to ease problem but now a few months later the problem is back! anybody any ideas?
Anti-roll bar links
Wishbones
TRE's
Steering column
Wheels not bolted on properly (don't laugh, I've had that!)
Suspension tops
Shocks
engine mounts
etc
etc
etc
:D
wrinx
:eek: Initial stage of a driveshaft CV joint going,it will get worse the further you drive and eventually the noise will be constant......and rather embarrassing :rolleyes:
:eek: Happened to me recently anyway ;)
Discussion Starter · #6 ·
problem located! its the upper strut bearing are fecked, on both sides :rolleyes: don't how safe it is to drive it like that! is it easy to chainge?
but! at least i know what it is now :)
how i found out was! i jacked up the car placed axel stands underneath a shuck the front wheels as hard as i could moving it back and too up and down, i heard a clicking sound comming from the top of the strut
i hope this helps you pipedip ;)
:) Nice one Andy! I'll Check that out on mine...
Hope it's not gonna cost a fortune, the wife won't be too chuffed! :tut:
Discussion Starter · #9 ·
if u can do it your self its £35 each for the part but i think u can get um cheeper!
1 - 9 of 9 Posts
