hi all
my 147 TI JTDm (06reg) has got a knocking noise from the front of the car...but only when cold and soon goes away, when warm
when i start the car, there is a knocking noise which appears to be coming from behind the drivers side of the car, i hear it clearly thru the dash(not saying its the dash)
after the car has been driven a few minutes it goes away
it also goes away when i rev the car
it also appears to knock over bumps
all this goes away after a few minutes when the car/engine has warmed up !!!
help :)
L
if it were my car i'd start by checking the stabiliser [ top most ] bracket of the engine followed by checking the mounting brackets for the exhaust.
cheers.
i'll look for the stabiliser tomorrow morning(when its cold )
they can be replaced quite easily? or just upgrade the bushs ??
its a jtdm engine
Is it a metallic noise?
I've got a cracked manifold shield (under dipstick) which rattles until it warms up. Didn't know it was this until i put force on the shield & the rattling stopped.
i think the noise is too "deep" to be a really metallic noise... more a knock rather than a tap :)
update.
what a plonker.......................
a couple of weeks ago, i took off the top engine cover, for another problem.
last night i put it back on
this morning.....no noise :)
hopefully that is it !!
now all i have to do is sort out my squeaky clutch !! the alfa fix's go on.
L
you'd have to wonder what is the top cover doing that is stopping this noise? try it for a few days with the cover on, then remove it to see if the noise comes back :)
