I have a 159 with 140Kkm on it.
Last year the knocking sounds started. I replaces the front upper wishbones at the time. They were worn and it cured 90% of the knocks at the time.
More knocks are back now. Front and rear.
What are the next common bushes to wear after the upper wishbones?
Check your power steering fluid levels. If they are slightly low the handling can become quite crashy and noisy. Worth a punt!
Also, grab some spray lubricant, jack up the car and douse everything that looks like it could be a bush or rubber on the front and rear suspension. That will cure a lot of noise.
If all else fails, I am sure someone more technical than me can point you at the next likely bushes to fail!
Not entirely sure. Something I have noticed through owning mine and confirmed by others. Seems as the fluid level drops it just gets a bit rough.
Sent from AutoGuide.com Free App
