Mkay, wanna use the 3 wire knock sensors from my 166 cf2 3.0 engine on my cf3 156 2.5 v6 loom(white 2 pin female plug).
Is this possible? I know the 2 wire is vsig + and vsig- where 3 wire has extra shield pin on pin 3.
TIA
Knock sensors, engine loom & ECU should be kept from the original 156 2.5 V6 engine, fit all the sensors/wiring from this engine to the bare 3.0 block (apart from injectors), thats the correct way to do it.
It's okay, I didn't do the conversion, hence why I needed info regarding using cf2 knocks with cf3 harness.
Some interesting info regarding the knocks that I discovered if anyone is interested:
3 wire and 2 wire are pretty much the same. the extra wire on 3 wire is merely shielding, which the 2 wire also has but terminates back onto the vsig- (signal ground wire) before the connector block.
Use pin 1(vsig+) and pin 2(vsig-) on either connector blocks, engine and sensor sides.
MES gives no knock errors and me butt dyno agrees
