Right got a 156 02 gta...
today the little key code illuminated on the dash and the car failed to start.
does this work of the little non-powered chip and if so is there a fix or is replacement the only solution.
also how many keys can be programmed at the same time.
where is the best place to get keys repaired or replaced. is it worth the using the lost key cover or is there a cheaper way to repair keys.
thanks
thanks
