Ok, next problem... The buttons on my switchblade key does not operate the central locking or boot. Apparently the previous owner decided to change the battery; he removed the old batter and then went hunting for a new one. It took him a while, after which he replaced the battery and the key did not work since.
Presumably it has lost it's code? Is there a way to get it back in sync or is it a dealer job?
Ta :)
My spare did that when I put a new battery in, I found if I repeatedly pressed the button it started working...I think it self configures itself..
Does the little red light flash when you press the buttons?
Tried repeatedly pressing but no joy. And... I can't see a light flash on the key (I don't know where it is even lol)
Silly question - did he put the battery in the correct way?
Discussion Starter · #6 ·
Yeah, battery is in the correct way around according to the diagram in the manual. The light does not light up when I press buttons so it looks like the key is knackered :( Battery definately has power; it tingles when I lick it lol
Discussion Starter · #7 ·
Just to check; the battery has the '+' side facing up when you look down on the top of the key, if you see what I mean
Discussion Starter · #8 ·
Finally an update to this, the previous numpty had put the battery in the wrong way... I switched it round, pressed and held both buttons down on the remote and 'beeeeeeeep' said the car :) Remote locking now works!
